HP LaserJet Enterprise 500 color MFP M575dn error 49.38.07
  • AlexSV
    • Feb 2013
    • 17
    [Error Code] HP LaserJet Enterprise 500 color MFP M575dn error 49.38.07
    We will bring together the greatest minds in Kyiv to solve the problem.
    The challenge is far from over.
    Maybe somebody can help us. Hello?
  • atadikohp
    • Apr 2017
    • 46
    Re: HP LaserJet Enterprise 500 color MFP M575dn error 49.38.07
    This is what I usually do when I got error 49.XXXX on HP printer.
    Turn off the printer, delete any unfinished job in the queue ( or at the work station). Power up the printer.
    If the error still there: power off the printer, disconnect network and usb cable, do a nvram init. , reconfig network setting.
    Last result: replace the formatter board
    • Lance15
      • Jun 2015
      • 1089
      A 49 error is usually ALWAYS a corrupted print job. I would NEVER perform an NVRAM Init for a 49 error.
      Power off the printer, disconnect the network or USB cable and power the printer back on. If it comes to READY, clear print ques (server and/or local).
      • AlexSV
        • Feb 2013
        • 17
        I don't mean to say you're not good enough. Well, I still haven't talked to JessupThe solution is very simple, I assure you. But your friends "hp-service" have been helping us out... Okay, well, there's a solution to this infocopy.net.ua
        Everything works and is actually VERY fast!
        • AlexSV
          • Feb 2013
          • 17
          You're just so incompetent.
            WOW!!!!! holy fucking SHIT!
            you come in here.. post a question
            when the Techs give you BASICALLY the same damn answer..
            you give them shit
            THEN
            post some crap
            Lance (if you ever read other forums) is one of the BEST with HP issues... he has helped and guided more users here than you will ever be able to...
            red flag and blocked
            • dsmith46
              • Oct 2016
              • 81
              [ATTACH=CONFIG]43551[/ATTACH]
              Completely uncalled for. GTFO here.
              • AlexSV
                • Feb 2013
                • 17
                About the other day, no need to thank me.
                  one AWSHIT removes ANY ATTABOYS you garnish ..
                  you were rude...
                  obnoxious
                  and frankly
                  A TOTAL PRICK
                  • AL parts
                    • Jun 2019
                    • 61
                    Reply from HP China
                    Hello, thank you for choosing HP products.
                    Disconnect all data lines or network cables, restart the printer, and see if an error is still reported. If an error occurs, please cancel all attachments and open them again.
                    If the error persists, reset the printer to factory settings (save the IP address and other information before proceeding).
                    Press OK to enter the printer's top menu - Manage - General Settings - Restore factory settings.
                    There is still a problem, please do the following: turn on the power, when all three lights are on (the three lights will light up after about 15-20 seconds), press the cancel button twice (this is the same as the previous one) The machine is different)) Too many, press once is absolutely inaccessible), you can see the following options, enter the pre-boot menu and select the administrator----(purtial clean / clean disk) startup option---cold reset
                    If you restart or cancel the attachment to start normally, the computer will output an error, which may be caused by a driver or software problem.
                    www.gzanling.com
