Hp 2550 /Error code
  • cucuklotz
    • Mar 2007
    • 611
    Hp 2550 /Error code
    Hi
    Machine goes into ready with ready lite coming on.
    I go to do test print thru display,and machine dosnt feed either bypass or cassette feed,It dosnt even try to turn rollers,although machine cycles. then I get 3 lites light up.Steady green on ready and steady green on warmup,and steady red on third indicator up(to put it another way, first 3 indicators light up from print buttom up.with the third one a steady red,while other 2 are steady green
    Thanks, Andy
  • gordie
    • May 2008
    • 83
    Hi
    You need to hold the go (green) button then report back with the lights that are on and I will be able to give you the fault.
    Gordie
    sigpic
    • cucuklotz
      • Mar 2007
      • 611
      HP 2550/Error Message
      HI,
      Thanks foy reply,Iwas able to find website thAT GAVE ALL ERROR CODES ON EVERY HP .It turns out to be fuser error code(low temp code)I orderered Fuser unit for machine.
      Thanks ANDY
        • 23008
        There is also a nice little diagnostic tool on the last tab of the print driver. It explains every combination of LED indicators. =^..^=
