print head
  • stobby2
    • Oct 2013
    • 137
    print head
    Hi Guys
    We have just intraded an HP T1200 42" plotter. Very nice condition however asking to replace print heads as out of date. Is there a way around this as a temporary measure as we need to test it to make sure it is in good working order before we invest in new heads.
  • Kiran Otter
    • Dec 2013
    • 1118
    Re: print head
    The date is only regarding the warranty. The printer will continue to print with out-of-warranty supplies.
    No, there is no way around the message. Replacing the printheads is the only way.
    Kiran
    • stobby2
      • Oct 2013
      • 137
      Re: print head
      Kiran
      Thanks Kiran
      I must admit we only ran it up stand alone. I will plug pc in and see if l can get it to print so we can test
      Thanks again for the info
      Roger
      • Kiran Otter
        • Dec 2013
        • 1118
        Re: print head
        Go to the Image Diagnostics menu and print the Image Diagnostic Print.. that will show you the status of the printheads. It should look like the image. If any of the large color blocks are missing, that printhead needs replacement.
        Kiran
        • stobby2
          • Oct 2013
          • 137
          Re: print head
          [ATTACH=CONFIG]43771[/ATTACH]
          Kiran
          Cheers Kiran.
          Run it tomorrow
