HP M525 scanner slit glass
  • tech07
    • Aug 2008
    • 409
    Have a HP m525 with a slit glass that has come loose and slid out of place. My question is :: Dont see a replacement top for the scanner. Just the whole scanner assembly.
    Any tips or tricks on this ?
  • 8T2
    • Aug 2015
    • 257
    Re: HP M525 scanner slit glass
    If you still have the glass can't you just glue it back in place? Not familiar with that model but on the older models both the slit and platen glass are stuck to the scanner housing anyway lol
    Sent from my WAS-LX1 using Tapatalk
    • tech07
      • Aug 2008
      • 409
      I wanted to but the top cover plastic is cracked and won't hold or glue back
      Was hoping to only order the scanner top cover that hlds the glass but only see the entire scanner unit in the parts catalogue.
      And not sure if it includes the top glass/slit glass holder
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        Scanner-assy is the complete scanner with glasses, cables, etc...
        Greetings...
        • tech07
          • Aug 2008
          • 409
          Originally posted by Zeldaman
          Hi there!
          Greetings...
          Many thanks..
