Laserjet 3 config report
  • mikadonovan
    • May 2008
    • 2931
    I need to know if you can print a configuration page from a HP Laserjet 3. If so, what is the procedure?
    NEVER ASSUME ANYTHING
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Is this for an Antiques store? No config report I know of. Self test prints, engine test prints. Any other help?/
    sigpic
      • 22999
      No config page that I know of on these antiques. Just a self test, which is just a demo print. No real config data on it. =^..^=
      • mikadonovan
        • May 2008
        • 2931
        We are trying to upgrade an account that has several of these old machines. No big deal, just wanted to see actual volume if possible. Thanks.
        • CopierTechofOmens
          Agitating Artificer
          • 268
          there is a counter in service mode
          sigpic
          • mikadonovan
            • May 2008
            • 2931
            How do I access service mode?
            • CopierTechofOmens
              Agitating Artificer
              • 268
              I had to go find the manual. They used to put those on paper in the before time of the long long ago. Ok
              3P: Press and hold the <Online>,<Menu>,and<Enter> while turning on. Makes a blank display. Press <Form Feed> then <Enter>. Should say SMODE and page count should be underneath.
              sigpic
              • mikadonovan
                • May 2008
                • 2931
                You just made my life a lot better. Thanks
                • prntrfxr
                  • 1627
                  actually 3P is a little different than laserjet 3 when going into service mode, but not much. The following procedure gets you into service mode for the laserjet 2,2D,3, & 3D printers:
                  Press ON LINE, CONTINUE/RESET and ENTER/RESET MENU simultaneously while turning the printer on.
                  Press CONTINUE/RESET, and then press ENTER/RESET MENU. After a few seconds the printer should display SERVICE MODE.
                  You know, my company sells parts and we still sell the fusers and AC power supplies for these things. If fact we have a hard time keeping them in stock. Which is amazing considering how old they are and that the parts are likely more money that an entire rebuilt one of these printers.
                  Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
                    • 22999
                    Thanks for the update prntrfxr. =^..^=
