HP LJ Ent 500 Color MFP M575f scanner control ribbon cable installation procedure
  • rdyjnkns
    • 135
    [Misc] HP LJ Ent 500 Color MFP M575f scanner control ribbon cable installation procedure
    I need to replace the scanner control ribbon cable (CD644-60105) on the above mentioned printer. The part number for the scanner is CD644-60110. Of course, there is no procedure in the repair manual. If anyone has done this and could assist, it would be deeply appreciated.
  • Lance15
    • Jun 2015
    • 1088
    Re: HP LJ Ent 500 Color MFP M575f scanner control ribbon cable installation procedure
    There isn't a removal procedure for the cable or whole scanner unit?
    • rdyjnkns
      • 135
      There is a procedure on how to remove the scanner from the unit. But not how to replace the ribbon cable.
      • Lance15
        • Jun 2015
        • 1088
        Sounds like it's one of those things you'll need to figure out on your own if you want to replace a cable and not a whole unit (which would probably include the cable).
