DJ 500 trailing cables order
  • theengel
    • Nov 2011
    • 1784
    I can't believe i got this mixed up, but does anyone know which slot on the electronics module is attached to which slot on the carriage pca?
    I wish those things were labeled.
    Or maybe they are and my eyes are too bad to see it.
    Re: DJ 500 trailing cables order
    from the manual power conn on bottom and flat cables at the top of the emod.
    i usually mark w/ a sharpie any connection I remove cuz my eyes ain't that great either.
    • Kiran Otter
      • Dec 2013
      • 1103
      You have a 50/50 chance of getting it right. If it's wrong you'll just get an 11:11 error. It won't hurt anything, thankfully.
      Kiran
      • theengel
        • Nov 2011
        • 1784
        Many moons ago I worked for a service company that repaired a cutter/printer. They had converted the DJ 5000 into a cutter. Part of it included a set of cables very much like the trailing cables--2 ribbons exactly alike. They folded over one another and it was a situation where they could easily be switched, depending on how they were folded. I ended up getting it wrong and blowing a $2000 board. I lost my job over that mistake... so I've been darn careful since then.
        • Kiran Otter
          • Dec 2013
          • 1103
          Yeah, on the 5x00 and especially the 105xC, if you got it wrong it would blow the main PCA. On the B models of the 1050 they finally put a fuse on the board because even HP's own techs were blowing boards left and right. I did it myself once.
          Kiran
