HP P4015 13.01 jam
  • Boringguy4
    • Aug 2015
    • 29
    HP P4015 13.01 jam
    Guys,
    I'm relatively new to in-depth HP stuff. I have a 4015 with jams from tray 3 (the extra cassette), paper stops right before the registration rollers. It will feed from tray 2 without issue. Gives a jam error of 13.01 (which pulls up as bypass jam). I took the entire paper path apart and cleaned sensors and tested motors and clutches. Everything checks out.
    Thanks.
  • Lance15
    • Jun 2015
    • 1086
    Re: HP P4015 13.01 jam
    Rollers okay in tray 3?
    The P4xxx series are starting to have issues with solenoids as well. The additional trays aren't repairable from the one I tried taking apart. Might just not have had enough time. Can't remember.
    • Boringguy4
      • Aug 2015
      • 29
      Since the 13.01 comes up as a tray 1 jam. I went ahead and just ordered the whole tray 3 assembly. Hopefully that will take care of it.
      My worry is it's a timing issue. Since it stops right before the registration rollers behind tray 1 and the reg paper sensor is after the rollers.
