HP LJ Pro MFP M127fn - still rotating fixing assembly
  • spree
    • Jun 2012
    • 211
    [Misc] HP LJ Pro MFP M127fn - still rotating fixing assembly
    Hello,
    when you power the socket to the wall - the HP LJ Pro MFP M127fn still rotating fixing assembly. Not matter when the cover is open or when the toner is out - still rotating.
    Any idea what to do?
    Re: HP LJ Pro MFP M127fn - still rotating fixing assembly
    Originally posted by spree
    Hello,
    it's supposed to rotate for a while...
    how long does it rotate?
    what have you done to trtoubleshoot
    you post is VERY VAGUE
    • FrohnB
      • Jul 2017
      • 1919
      Running with cover open and toner cartridge out - maybe one of the interlock switches is stuck/ bad?
      Could be a bad formatter.
      Does "Initializing" stay on the screen?
      Omertà
      • spree
        • Jun 2012
        • 211
        It is neverending rotating. Tomorrow I see if it stucks at "initializing" (now I do not remember it) - maybe formater, we will see..
          does it say "close open door"? if NOT it could be a door switch gone bad...
          there are so many things you could have going on but with the lack of info given we could be at this all year long!
          any supplies/parts @ EOL?
          you are there with the unit ..we are not so we have to run with the few details you have provided.
          • spree
            • Jun 2012
            • 211
            At the display is nothing, only backlight at display. When I power it OFF (with switch near display) the display is black (like OFF), but the rotating is still there. I think formatter is bad.
            • Lance15
              • Jun 2015
              • 1089
              My guess would be either the formatter, as you mentioned, or the ECU. Very low-end, low quality model. Hard to justify repairing. Very few parts, hard to repair (the more compact they are, the harder they are to fix). Labor can easily make the repair more than the current worth of the unit.
