HP DJ Z5400
  • aAandy
    • Apr 2012
    • 370
    HP DJ Z5400
    helloooo!!!
    have a machine which is calling new & full inks 'faulty', check the ink info and the expiry date on the 'faulty' carts is showing as 01/01/1970 12:00am where the others are showing a future date - all inks have a printed expiry date of 2021 and the good inks show that date in the ink info
    anyone know of a work-around? can i just change the date in the machine to 1970? is there a firmware fix?
    any tips very much appreciated
    thanks in advance
  • D Hook
    • Mar 2018
    • 205
    Re: HP DJ Z5400
    Don't have a helpful answer for you but tagging in to follow in case a solution is posted. Had the same problem with a different model and never found a solution. Tried new firmware update, new cartridges but nothing helped. Ended up just parting it out.
    • D Hook
      • Mar 2018
      • 205
      Re: HP DJ Z5400
      Found the thread about the same problem I had with a T790:
      HP Designjet T790 Faulty ink cartridge message
      Might answer some of your questions.
      • Kiran Otter
        • Dec 2013
        • 1115
        Re: HP DJ Z5400
        If the cartridges are under warranty (before the date on the cartridge) then return them and get replacements. Always rule out consumables before attempting to fix the printer.
        If multiple cartridges have the same issue, then you either have a bad ISS (ink supply station), check it for contamination by ink or other foreign substances; Or you have a bad main PCA which the ISS plugs into.
        Kiran
