Hp 700 color streaks when making black and white copies
  • DOE
    • Mar 2010
    • 258
    Have a hp 700 that is making color streaks when making black and white copies. Looked at transfer belt and it was clean and still has a 1/4 of its life left. I usually work on Konica’s and transfer belt is usually the cause. The one in this machine is clean with little wear on belt. Would you say transfer belt is still the problem
    Re: Hp 700 color streaks when making black and white copies
    please post examples in PDF format.
    have you done a stop test? do you see streaks on the ITB
    what about the toner/drums are the Genuine OEM or crappy remans?
    with the info you've given it would be pissing in the dark to make a guess.
    • 1stcavvet
      • Apr 2015
      • 231
      what ever color comes out on the paper that does not belong there, that toner cartridge is failing change that toner
      • DOE
        • Mar 2010
        • 258
        Installed remanufactured transfer belt. After installing oem magenta toner unit. With new unit getting 1/2 inch magenta dash marks every two inches from lead to trail on transport belt. Is this a toner unit issue or transport belt issue. Thanks
