Up 700. Red print is light and off color
  • DOE
    • Mar 2010
    • 258
    I have an HP 700 that when you print a color copy the red is light and not the right shade. I went into device management and did the calibrating cleaning in the full calibrating and it made no difference. The rest of the color look fine. The magenta cartridge still has over half its life left but would you look at replacing that. Thanks
    • 22804
    Re: Up 700. Red print is light and off color
    bet they aren't genuine oem HP toners
    • Lance15
      • Jun 2015
      • 1071
      Like Phil said. Are Genuine toners being used?
      • DOE
        • Mar 2010
        • 258
        We had a new magenta unit but it isn't oem. It made the red a little darker(still not right shade) but is also leaving dash marks on transfer belt. Is all this from not being a oem drum.
          • 22804
          DOE
          I clue you into HP laser based units.
          THEY DON'T PLAY WELL WITH GENERIC TONERS.
          EITHER GET YOUR CUSTOMER TO SWITCH TO GENUINE OEM OR drop them like a hot rock.
          • Mr Magic
            • Jan 2020
            • 29
            OK!
            • Clean the ID Sensors
            • Let the machine power-up and run the calibration again
            • Update the FW (remember to print config and demo pages) then compare on completion
            All the best!
