HP DesignJet T525 36"
  • menosmola
    • Apr 2014
    • 95
    Hi, i have a customer with an HP DesignJet T525 36 inches with a paper roller 24 in x 150 ft
    When try to print from Autocad or other application with size A1 the plotter allways says the size in wrong...
    Any ideas of configuration that i must check?
    Re: HP DesignJet T525 36"
    why aren't they using paper size appropriate for the paper?
    • menosmola
      • Apr 2014
      • 95
      I'm not too familiar with AutoCAD, and the client doesn't seem to configure it correctly.
      I would like to know if someone could tell me the correct steps to select a type of paper in autocad.
        WHAT ARE THEY PRINTING?
        with out the simple info it's hard for us to help you
        • Kiran Otter
          • Dec 2013
          • 1100
          This is just a guess but the printer thinks it has 24" paper loaded, and you're telling it to print on A1 paper which is slightly narrower, so there's a mismatch. Print using an Arch D paper size and I think you'll be OK.
          Kiran
