HP Laserjet 600 M601 swing plate
    • 23009
    I have one in my future ...
    I've done the swing plate on the 2430, the 4100, and the 4345. It isn't too bad, is it?
  • scanmc
    • Mar 2015
    • 183
    Re: HP Laserjet 600 M601 swing plate
    if you've done a 4345 this is much easier. The only thing I hate is removing that plate above the transport section to get to the one screw on the swing plate. Have a little stubby screw driver in your case for those two screws. All the 4200 4300 600 series are basically the same routine. Good luck
    • RMC8112
      • Nov 2019
      • 38
      its not too bad. first time will take you prolly 1 to 2 hours. ive done 4 so far and it gets easier. hp-p4015-m600-series-grinding-from-fuser.pdf
