T920 plotter
  • 1stcavvet
    • Apr 2015
    • 231
    [Error Code] T920 plotter
    Customer called said they are getting a message on their printer "faulty communication with firmware server" they said they tried to install new firmware---not sure if it was the reason they tried that or is their problem after trying to do firmware update anybody have any idea what I should be looking at or where I should start---- they said it gets to about 94% then says that on the display I'm going to check the leds to see if that gives me any clue. any ideas would help thanks Courtney
  • Kiran Otter
    • Dec 2013
    • 1106
    Re: T920 plotter
    If I had to guess (which I'm usually doing) it's because their firewall is blocking the site HP uses to store the firmware. Manually update it (if you must) and disable the automatic firmware update.
    Kiran
    • 1stcavvet
      • Apr 2015
      • 231
      Re: T920 plotter sorry it's a t1300
      Sorry this is actually a t1300 not a t920 I'm figuring is the same sort of issue their IT guy said he updated the firmware ---so he probably never got it pulled down he thinks he downloaded something that never happened THANKS FOR YOUR INPUT Courtney
