HP 500 42'' DESIGNJET
  • Polo-022
    • Sep 2007
    • 486
    I had a call to replace a worn carriage drive belt.
    Customer told me that his last print was totally blank.
    I did the replacement procedure hoping to override the blank prints.
    Printheads alignment is cancelled by itself everytime i do the procedure and nothing is printed
    from any application, internal prints either! No service code, no other message, it goes to ready.
    What could it be?
    Thanks alot for any input...
  • Kiran Otter
    • Dec 2013
    • 1114
    Re: HP 500 42'' DESIGNJET
    I'd say you've got 4 bad printheads then. Replace them first before throwing other parts at it.
    Kiran
      Kiran
      +1
      • Polo-022
        • Sep 2007
        • 486
        Kiran
        Do you mean 4 printheads at the same time? How could it has to be done???
        There is no message for a faulty printhead or something.
        Menu says printheads "ok".!!!
        Thanks Kiran, Phil.
        • Kiran Otter
          • Dec 2013
          • 1114
          It's entirely possible if the printer has been sitting a long time. Get just one (black) and replace it, see if you get black printing.
          You can try cleaning them with a damp paper towel (just water.) Strike them into the paper towel and wipe them; if you see two streaks of ink then you're getting something out of them. And the printer has no idea if they're working or not, really. Don't trust what the front panel says.
          Kiran
            Kiran
            i've had good luck using Simple Green on the paper towel.. it's organic .. does a pretty good job of busting up any ink from Ricoh - HP - Brother etc.
            I let the ports sit on the paper towel for a bit then while still on the towel, squeeze the sides allowing the SG to enter the ports a bit the run purge on the in the printer .. then test prints.
            Simple Green(R) Original - 1 Gallon S-7290 - Uline
            • Polo-022
              • Sep 2007
              • 486
              It was printing perfectlly two days ago, color drawings.
              Suddenly and during print, it happened, totally blank!
                clean the printheads first then if no go replace them.. how much life left on the PH's.
                • Kiran Otter
                  • Dec 2013
                  • 1114
                  Ok. When you disconnected the trailing cable from the carriage, was it in good condition? No bent fingers? You might want to check it again. I've never had one 'work' but not print due to a bad trailing cable but anything is possible.
                  Aside from that, I would at least replace the black printhead. Always rule out the consumables first. They're not that expensive.
                  Kiran
                  • Polo-022
                    • Sep 2007
                    • 486
                    Thanks a lot for your replies.
                    No, i didn't see a bad trailing cable.
                    Of course i will replace printheads first...
                    • Polo-022
                      • Sep 2007
                      • 486
                      It was a faulty yellow printhead. causing the above symptoms.
                      Thanks again!
                        Thanks again!
                        thanks for letting us know about the fix!
