Help! Chaning the printer serial number on HP P2035
  • atadikohp
    • Apr 2017
    • 46
    I just replace a formatter board on this printer and need to change the serial number of the printer. Anyone here has a PJL command to do this? I have try the one below, but no luck at all:
    %-12345X@PJL JOB
    @PJL SET SERVICEMODE=HPBOISEID
    @PJL SET SERIALNUMBER=XXXXXXXXXX
    @PJL SET SERVICEMODE=EXIT
    @PJL RESET
    %-12345X
  • Lance15
    • Jun 2015
    • 1089
    Re: Help! Chaning the printer serial number on HP P2035
    NOTE: The product must be directly connected to the computer with an IEEE-1284 compliant parallel cable. PJL commands cannot be sent down to a printer that is connected via a USB connection.
    I haven't used this process in MANY years and only a handful of times in the parallel days. Unless it's a printer that has that function in the Service menu, I don't bother.
      This works on a m477 that is set up as a shared printer on the network using a dos command
      ESC%-12345X@PJL SET SERVICEMODE=HPBOISEID
      @PJL SET SERIALNUMBER=************
      ESC%-12345X
      You may find more info here
      how do you input serial number
