HP designjet t3500 6.21.10
  • javier4065
    • Feb 2007
    • 251
    I have this problem, i changed Main formatter pca , what can I do to solve this
  • javier4065
    • Feb 2007
    • 251
    Re: HP designjet t3500 6.21.10
    Display says 06.21.10 , I changed Main pca, Wsomebody can help me? I buyed it fron China it looks like used Maybe i need change Hdd .the question is if I have to change another parts because the Main pca is used thanks in advance
    • Kiran Otter
      • Dec 2013
      • 1109
      Could you give us the part number you replaced, just to verify what part you're talking about?
      And why not just replace the hard drive? HP has them in stock.
      Kiran
      • javier4065
        • Feb 2007
        • 251
        Kiran
        thanks friend, the first problema was white display that si the reason because I bougth the formatter board then I installed it and now the display says 06.21.10 the seller said that I must changed the HDD . My question is if I change Hdd i sould change another parts like simm encripted thanks Maybe the formatter si used
        • Kiran Otter
          • Dec 2013
          • 1109
          The manual states: For T920, T1500, T2500 revB SKU, and T3500 all SKUs (A and B), remember to replace the formatter together with the Hard Disk Drive.
          So I would replace the hard drive, yes.
          Kiran
