HP HD pro scanner
  • Arcadian
    • Feb 2010
    • 218
    HP HD pro scanner
    Getting a 55-1003 Error after trying to calibrate the lamp, new module installed and still getting this.
    Can someone help, i can access the support menu but doesnt help very much.
  • Kiran Otter
    • Dec 2013
    • 1115
    Re: HP HD pro scanner
    Are you certain that's the error? Because I see no 50-1003 listed. I would clear the parameter blocks and run the calibration again.
    Kiran
    • Arcadian
      • Feb 2010
      • 218
      Kiran
      i know ive looked as well, this is why im posting here.
      here a picture of the screen, this is after trying to run the calibration
      i dont know why it went sideways
      • Kiran Otter
        • Dec 2013
        • 1115
        Ok. Well, clear the parameter blocks as I suggested and try to calibrate it again. Let us know what happens.
        Kiran
        • Arcadian
          • Feb 2010
          • 218
          Kiran
          ok ill try that if i can find the parameter clear, usually it pops up on a t1100 scanner but these are different. thanks again
