HP Color LaserJet CM3530 MFP giving "59.F0 Transfer unit is missing or motor error"
  • ccr
    • Mar 2021
    • 31
    Hi,
    I just registered here as I have an issue with my HP Color LaserJet CM3530 MFP I use for my home business. As I attempted to print an invoice I could hear the motors just suddenly stop mid print and it displayed:
    "59.F0 - Error
    The transfer unit is missing or a motor error has occurred"
    I did motor/sensor/ITB flag tests which all passed however another post mentions Sensor SR9 but doesn't mention where this sensor is so I haven't tested that one. The sensor I did test is sensor SR17 which works.
    Also, I believe it's since I tried manually turning the gears that engage with the transfer belt assembly, there's a faint grinding noise when it starts before it gives the error, when the error first occurred it wasn't doing this grinding noise. What could this new noise be? It doesn't sound too bad, I don't think teeth got broken off gears but it does it every time it starts, would it be worth recording it and posting the sound?
    What should I try next and is it worth fixing? It's probably over 15 years old but I really like this machine and would like to either fix it myself or get it fixed depending on the complexity of the job. I just bought a portable HP Officejet 200 as an emergency backup printer to keep my business going in the meantime and in case of future problems.
    It would seem like a waste to get rid of my LaserJet when it's hopefully an inexpensive fix, it's a huge machine with possibly just a faulty or dusty sensor. I'd be willing to put a few hundred dollars into it as long as it gets it fixed.
    Thank you
  • ccr
    • Mar 2021
    • 31
    Re: HP Color LaserJet CM3530 MFP giving "59.F0 Transfer unit is missing or motor erro
    I just found the source of the grinding noise, while I had the fuser and ITB removed, I manually turned the upper most gear that engages with the fuser unit and when I turn it upward I hear that grinding noise but not when I turn it downwards. What would be causing this? It didn't start doing that noise until I started playing around inside to try to fix the error.
    Edit:
    The grinding noise stopped as mysteriously as it started, even when I manually turn the gear I no longer hear it.
    I've also tried to upgrade the firmware as I heard it can solve this error though I suspect a real hardware issue with the age of the printer but it seems like it refuses to take an upgrade with the error displayed, is there any way to upgrade the firmware when it starts with an error?
    I've also read more and more about this often being caused by a failed solenoid and saw videos on how to get to it, is this likely my issue?
    • ccr
      • Mar 2021
      • 31
      The grinding noise is back again, and after more research it seems this error is often caused by a sticking solenoid, and it seems to be on the fuser drive assembly which is also where the grinding noise is coming from.
      I think replacing the fuser drive assembly and the solenoid it contains may fix the issue, what do you think?
      The part is cheap but seems like a several hour job to get to it.
      • Lance15
        • Jun 2015
        • 1089
        Correct. The fuser drive assembly will need to be replaced. It is inexpensive, however, unless you've got printer repair experience under your belt, it's not something a user should do.
        • ccr
          • Mar 2021
          • 31
          I'm not a printer tech but I have repaired many things including printers (though possibly only inkjets other than minor fixes on my laserjet) and replacing the screen of my smartphone myself which was like brain surgery, I've seen videos on YouTube showing the repair I need to do, it's admittedly the most complex repair I would have done (mostly the disassembly and reassembly) but I feel ready to try it.
          In the event that I make it even worst, would a printer tech service it in a home business? How much could I expect this repair to cost if I were to pay a printer tech to do it?
          After looking at printers available today I think I want to get my 15+ year old laserjet fixed over getting a new model, am I pushing it on wanting to keep using a 15+ year old laserjet? It only has 95 000 pages if I remember correctly.
          BTW it had sometimes been leaving faint streaks on either side of pages that eventually fade out and then come back, I'm quite sure this is an ITB issue but could it be just a bad/dirty wiper? I've seen the wipers for the ITB sold by themselves, could that fix my streaking issue or should I get a whole new ITB? Print quality is still impeccable other than the occasional streaks.
          • Lance15
            • Jun 2015
            • 1089
            In my opinion, if a user tried tackling a repair like this and made it worse, I wouldn't even touch the printer. Believe me, printer techs KNOW when someone has been inside of printers to try to fix problems.
            And you are correct for the streaking issue. It is a faulty ITB. Typically, the whole ITB is replaced as the "cleaning assembly" isn't a separately replaceable part, but, if your feeling adventurous and you have a source to order only the cleaning end of the ITB, expect to make a complete mess. The cleaning assembly is filled with toner. I've taken one off once just to see if it was possible to clean and it wasn't pretty. Toner everywhere.
              +1
              if I did touch it I would charge DOUBLE TIME to fix it.
              • ccr
                • Mar 2021
                • 31
                What could have caused the grinding noise that started that comes from the fuser drive assembly? Again I was getting the error before the noise started and the noise started after I manually turned some gears that engage with the fuser and ITB, could simply manually turning these gears have caused the grinding noise? I assume replacing it will solve the problem but I'd like to know what could have caused it so it doesn't happen again on the new one.
                If I didn't try to fix it myself and paid a tech from the start, how much would it cost and would they come fix it in a home?
                • Lance15
                  • Jun 2015
                  • 1089
                  The grinding noise could be from any number of things. Fuser, registration assembly, fuser drive assembly, main drive assembly.............
                  Depending on who you can find to come out will depend on price. Personally, I don't do this repair onsite due to the number of components that need to be removed. Haven't found one place that had the room to accommodate my meticulous laying out of parts so I know where they go back .
                  As for amount of time. I've gotten this repair down to under two hours. This also includes testing and updating to the latest firmware. It's A LOT of work.
                    +1
                    The real-estate it take to dismantle this bugger can be enormous.
                    I would take these to my shop.
                    • ccr
                      • Mar 2021
                      • 31
                      After watching videos of it being done I think I feel comfortable attempting the repair myself but I do have some concerns:
                      -I see there are lots of plugs to unplug from circuit boards, is every plug unique ensuring you can't plug a wire in the wrong plug or do you need to figure out a way to remember which plug goes where (in the video he's just yanking them all out one after the other so I assume it's fool proof)?
                      -The videos all show the printer only version, I have the MFP, how much more complicated is it to remove the scanner top compared to the plain piece of plastic on the printer version?
                      -The videos show replacing only the solenoid on the fuser drive assembly, I prefer to replace the entire fuser drive assembly especially as that's where the occasional grinding sound comes from, is there anything more to remove to be able to remove the entire fuser drive assembly?
                      -Videos show the power supply being removed though it doesn't seem to be in the way at all, is this for safety reasons?
                      Thank you
                      • Lance15
                        • Jun 2015
                        • 1089
                        I would start here and become familiar with the process:
                        ftp://ftp.hp.com/pub/softlib/softwar...ice_Manual.pdf
                        When I do this, I still take pictures of certain components with a lot of connectors. Mainly the DC Controller. A lot of times, the wires line up with where they connect, sometimes they don't. Yes, usually the connectors are unique that can only go in one place.
                        • Lance15
                          • Jun 2015
                          • 1089
                          There are a few shortcuts that I've learned over the many I've replaced. The biggest one is when the service manual is having you to individually remove the LVPS, IDC and formatter cage. All three of those can be taken out as one large unit.
                          • ccr
                            • Mar 2021
                            • 31
                            Thanks a lot for the service manual, it explains how to remove the scanner/control panel top which I hadn't found a video on how to do.
                            Another concern I have is one video in a foreign language mentioned something about a double tooth gear on the fuser drive assembly, I got it delivered today and I can now see this double tooth gear and it has been taped firmly in place so it doesn't move during shipping.
                            What exactly do I need to pay attention to in regard to this double tooth gear?
                            The manual also has me remove the main drive assembly to replace the fuser drive assembly, in videos I saw replacing only the solenoid of the fuser drive assembly it looks like removing the main drive assembly isn't required, is it?
                            I'll try to get this done tomorrow.
                            Edit: Another thing, on the fuser drive assembly I got there doesn't seem to be grease on the plastic gears, is this normal?
                            Since changing the entire fuser drive assembly seems to require removing the main drive assembly and changing just the solenoid on the fuser drive assembly doesn't, I'm considering just swapping the solenoid, what do you think?
                            BTW since this printer is over 15 years the scanner cover has yellowed with age, if I succeed in fixing it I may want to replace the yellowed cover to make it look new again, is it an available part and is it expensive? I wouldn't want to pay much just to replace a yellowing cover.
                            • Lance15
                              • Jun 2015
                              • 1089
                              The main drive assembly is probably out of alignment, so, I would remove it and realign per the service manual.
                              Use the service manual for the part number for the scanner cover that is yellowed.
