Hp laserjet P2015 & 1320
  • Abimotek
    • Feb 2015
    • 59
    [Dead] Hp laserjet P2015 & 1320
    Hello, pls I want to convert my hp laserjet p2015 to 1320, pls guide lines on parts need to change. to double check if it will work with mine 😳
  • makeacopy100
    • Oct 2019
    • 24
    Re: Hp laserjet P2015 & 1320
    Hi there sir as you say that you want to convert your hp 2015 to 1320, the both models have different formatter board and bypass paper feed system, as these structures are too difficult to change so its nearly impossible to convert these printer
    • Drivee
      • Nov 2020
      • 322
      Usually people will convert cartridge 53AX to 49AX, it is easyer than to convert a printer.
