Reset chip / W2030X - HP 415X
  • Brolle
    • Mar 2021
    • 3
    [Error Code] Reset chip / W2030X - HP 415X
    Hi
    Is there anyone here who knows if it is possible to reset the chip to toner W2030X-HP 415X and how in that case?
    Thanks in advance and happy easter :-)
  • GIUBOSS
    • 1435
    Re: Reset chip / W2030X - HP 415X
    Originally posted by Brolle
    Hi
    Welcome to CTN ... I don't know why you are looking for a chip resetter and especially if it is convenient to reset probably used cartridges ... have you tried compatible toners?
    • Brolle
      • Mar 2021
      • 3
      Thanks for your reply.
      I bought one toner without a chip and had to move over the other. but then it shows that the toner is empty.
      That's why I want to reset the chip.
        as far as I know there is no resetting a chip.
        you can purchase 3rd party chips off of the internet
        • Drivee
          • Nov 2020
          • 322
          There is a way to reset that chip but for you as end user is not cost efective. Apex have Unismart for reset. I will agree with Phil, just bay aftermarket chips and problem is solved.
          • Brolle
            • Mar 2021
            • 3
            Thanks for the answer, cant find any on internet, do you know where?
              if he has updated to the latest firmware .. the compatible carts will show a " supply error " message. Some guys here have the older firmware that they are willing to share.... so that might be an option to try.
              • tech28
                • Jun 2013
                • 434
                There isn't yet, only OEM cartridges will reset counters. There are other post pertaining to that. When you update the machines firmware, you cannot use compatibles anymore.
                They start at the newer series HP's. The older unit's are still good though with updating and running compatible toner's.
                  thank you Sir... not sure where this user is from but Static Control sells ( or they used to ) the chips.
                  Ink jet & laser toner cartridge supplier | Static Control
                    +1
                      Re: Återställ chip / W2030X - HP 415X
                      try these guys.. they do have offices in europe also.
