Laserjet M477fdw supplies error
  • Leebs14
    • Feb 2014
    • 457
    [Error Code] Laserjet M477fdw supplies error
    • 30293
    Re: Laserjet M477fdw supplies error
    The printer performs correctly, but 'Supply Memory Error' displays on the control panel. To resolve this error, make sure that there is not any packing material in the printer or on the print cartridge, or replace a defective cartridge.
    Fix HP "Supply Problem/Error" Message (How to Rollback the Firmware in Your HP printer) - Print.Save.Repeat.
    • GIUBOSS
      • 1436
      I had a similar problem with an M281, on the official website there is only the latest firmware version that does not accept non-OEM cartridges in the printer, you have to search for it on the web from alternative sites.
      • Leebs14
        • Feb 2014
        • 457
        [QUOTE=Leebs14;1732229]
        • tech28
          • Jun 2013
          • 434
          Just put another toner in. The compatibles are about 13.00. will take care of problem. We sell tons of toners, all compatible, the newer machines, like the M 479, M 528 DO NOT TAKE COMPATIBLES. Distributer say's by July or August there will be for those machines though. Will have to wait and see. Good luck. God Bless America!
          • Drivee
            • Nov 2020
            • 322
            One of your chip do not work. That printer dont have problem with Non-OEM and Firmware. If you already use Non-OEM cartridges then another set need to work. Take picture of your printer display and I will tell you what colour have defective chip.
              Just seen the compatibles for the Hpm479, this is funny you get a pair of tweezers in the box the only other tools required are a pair of wire cutters. You cut the plastic on the old toner where the chip sits, place it on the new one and set the toner low to continue for some time. Sorry I don't have the precise instructions, but you get the idea.
