hp color laserjet 5550 dn problem
  • masb23
    hi i have a hp color laserjet 5550 and the display show download file now RFU load error resend RFu over parallel port
    anybody know what is this?
    help please
  • prntrfxr
    • 1622
    You need to update firmware. I've included instructions with this post. See attachment. If this doesnt work, you'll need to replace the formatter.
    Did you replace any boards on this machine recently. sometimes it occurs when a DC Controller from a non-duplex machine gets put in a duplex machine (and vice versa). Do not ever replace the DC Controller and Formatter simultaneously. Always replace one, power up to ready, power down and then install the other. Always perform multiple calibrations afterwards (at least 3). Hope this helps you.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • jtymabel
      • Aug 2008
      • 164
      had a similar issue on a hp p3005. you must load the firmware thru usb port.
      disconnect printer, delete current driver. restart pc. when ready, connect usb cable to printer. pc should recognize printer. (load drivers, if pc does not do so automatically.) after the drivers are installed make sure you share the printer (right click on printer icon and share printer. make sure you give it a shared name...for example laserjet5500)
      open command prompt and type.
      copy /b filename \\computer name\share name
      firmware pc name printer share name.
      i did this a couple of times...you can turn the printer off and on if it does not work for you the first time. don't turn off if downloading firmware.
        • 23010
        Thanks prntrfxr. I can only hope that I never need this information. =^..^=
        • pinheiro
          • May 2009
          • 51
          Hi,
          I got a HP 5550. I can ear the fans and motors but no display at all. I have test all boards in working mc and it's look perfect. Can someone help???
          • prntrfxr
            • 1622
            Hi,
            Make this a separate post as its a different problem and I'll be happy to post an answer.
