HP T1120 scanner
  • Ajaxfan77
    • Sep 2009
    • 48
    HP T1120 scanner
    Hi everybody
    Is it possible to scan to usb without printer (stand alone scanner), usb doesn't work by monitor only from back usb. Machine SD-MFP T1120 (only scanner)
    Thanks in advance
  • Kiran Otter
    • Dec 2013
    • 1115
    Re: HP T1120 scanner
    Absolutely. The scanner is sold by itself. It doesn't need a printer to scan to USB or a network share. You should be able to use the side USB port... maybe it's broken?
    Kiran
    • Ajaxfan77
      • Sep 2009
      • 48
      Kiran
      Im going to check it
      Thanks a lot for help
      • Ajaxfan77
        • Sep 2009
        • 48
        Kiran
        Thanks a lot Kiran but where i can disable the printer?
        • Kiran Otter
          • Dec 2013
          • 1115
          I don't remember exactly where, but there is a place to add/remove printers. If you're not using a printer you can just ignore it, I would think.
          You may find the user manual helpful. http://h10032.www1.hp.com/ctg/Manual/c04493219.pdf
          Kiran
