Fuser grease
  • ebulich
    • Jul 2010
    • 46
    Fuser grease
    Would appreciate if people could tell me what kind of grease they are using on fuser rebuilds. I am struggling to find any high quality fuser grease in Australia
    • 22997
    What are planning to lubricate? Drive components? Heat sleeves? Creaky bushings? It makes a difference.
      • 37357
      What temperature range does it need to be usable over?
      • ebulich
        • Jul 2010
        • 46
        It would need to be stable at the 180 degree celcius mark. i Have found the grease Ricoh use in their machines and its cost me $350 + for a 50 gram tube.
        Thank you for your reply
          • 37357
          Try super lube. It is a Syncolon (PTFE) based grease. Here in the states it is available at Home Depot and other hardware stores.Also available from Amazon. A little $10.00 US. for a 3 OZ tube
          61fRXEk295L._AC_SL1500_.jpg?
          • ebulich
            • Jul 2010
            • 46
            Yep tried that on another machine and failed within 2 weeks. The heat dries out the carrier in the lubricant and you are left with a black paste with little lubricating properties. But thanks for trying
              • 22997
              Did you specify what you are lubricating? I don't see an answer. =^..^=
