HP T 730
  • Hoosierdaddy
    • Oct 2016
    • 181
    HP T 730
    It prints about 3 or 4 lines and stops and says " The printer could not remove the paper automatically. Remove the paper Manually to continue. I have replaced the Line Sensor and have heard maybe the printhead can cause this issue, Has anyone seen this problem?
    Thanks in advance
    Hoosierdaddy
  • Kiran Otter
    • Dec 2013
    • 1107
    Re: HP T 730
    I found this. hp designjet t730 could not remove paper automatically - HP Support Community - 6305649
    I would run the Paper servo, OOPS, Output tray sensor and Rewinder motor tests.
    Assuming you're using roll media, make sure the paper is not able to spin on the core. If the printer thinks the roll has stopped turning but it can't find the end of the media, it gives that message. Or if the spindle isn't engaged with the take-up motor or gears.. which I think that above link is relating to.
    Kiran
