HP PageWide P777x0 not waking from hibernation
  • KayDot
    • Jul 2020
    • 12
    [Misc] HP PageWide P777x0 not waking from hibernation
    We have a few of these devices in the field, and a fair bit of them requires a powercycle in the mornings to wake up from hibernation.
    Different firmware versions have been tried, the sleep timeout has been set to 2hrs, the wake-up feature has been enabled for every morning, and different power sockets has been tried - all to no avail.
    When contacting HP they tell us to change either the formatter or the display, this has also been tried - also to no avail.
    Has any of you experienced this, and if yes, found a way around it?
    Cheers,
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: HP PageWide P777x0 not waking from hibernation
    Uncheck the sleep mode so it doesn't engage
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • KayDot
      • Jul 2020
      • 12
      Good call, but unfortunately that isn't an option (as far as I see it);
      Unless of course there's an option somewhere on the P777x0 series that I don't know of (Which is highly likely )
      • Venom
        • Nov 2009
        • 765
        log into EWS, settings> energy save settings> optimum speed/energy usage> change save energy to faster first page
        • Venom
          • Nov 2009
          • 765
          this prevents deep sleep from preventing wake up on network
