LaserJet 2420 grey background - posted on behalf of AlanHK
    • 8164
    Re: LaserJet 2420 grey background
    Originally posted by AlanHK
    Yeah, that seems likely. I asked in the manuals forum for some docs on the cartridge and got a remanufacturer's manual.
    That included a list of common problems:
    Which describes the printout pretty much.
    I assume the dirty drum is consistent with this.
    Since this happened after I moved the previously good cart to a "new" machine my assumption was that the problem was the printer. But I guess transferring the cart somehow damaged it. Maybe a poor electrical contact.Though I've taken it in and and out of the first printer dozens of times to clear jams.
    I've had a few carts broken out of the box, but none that have failed in service before.
    This shows the slit glass, I think? On the top of the cart; no shutter though. The only shutter is on the bottom, over the drum.
    A smear of toner on the left. Cleaned it but print quality not improved. Still plenty of toner marks on the drum. So this is a symptom, not a cause.
    So: seems clear the problem is the cartridge, so will replace.
    If my wife allowed me to keep the old printer and its cart I would have been able to swap it in to confirm, but such are the constraints of working from home...
    Might try to crack the cartridge. Probably can't fix it without new parts but it will be educational.
    I'm sure that's true, but the HP cartridge is A$379.97. Compatibles are $25-$35. In 30 years I've only had a few issues with non-HP carts, so I accept the risk. Larger businesses may have a different calculation.
    But found someone local reselling a genuine HP cart almost as cheap, so will see if I can get that.
    Thanks all for the advice.
    I had a quick look on eBay & there a loads of new Genuine HP Q6511X 11X cartridges for peanuts.
    HP 11X/Q6511X Toner Cartridge Black SHOP.INSPIRE.CHANGE | eBay
    • AlanHK
      • Mar 2021
      • 24
      I had a quick look on eBay & there a loads of new Genuine HP Q6511X 11X cartridges for peanuts.HP 11X/Q6511X Toner Cartridge Black SHOP.INSPIRE.CHANGE | eBay
      Interesting, thanks for heads up.
      Until recently I lived in Hong Kong, and ebay is uneconomic there, ridiculous shipping fees for almost all items.
      More local vendors in Aust.
      • Drivee
        • Nov 2020
        • 322
        Re: LaserJet 2420 grey background - posted on behalf of AlanHK
        Your wiper blade is defective.Change cartridge or change wiper blade.
