HP Designjet 500 Error 79.04 on startup
  • borios66
    • Nov 2021
    • 4
    [Error Code] HP Designjet 500 Error 79.04 on startup
    Hello
    i got problem with mny DJ500
    Yesterday it said that one of Printhead is going to be out of warranty.
    Today my DJ dont even start up and said 79:04 error.
    Do you have any solution on this? I tried to put out all printheads + inks and start again, but nothing happened.
    Thank you for any suggs.
  • Kiran Otter
    • Dec 2013
    • 1109
    Re: HP Designjet 500 Error 79.04 on startup
    So as not to duplicate efforts, let's continue here and not in PMs.
    Once you remove all the printheads and inks, and printer/network cable, what happens? 79:04 or something else?
    Kiran
    • borios66
      • Nov 2021
      • 4
      Kiran
      Hello again it says 79.04, without any belt movement or starting the heating processs
      • Kiran Otter
        • Dec 2013
        • 1109
        Does it have a network card? Try removing it.
        Kiran
        • borios66
          • Nov 2021
          • 4
          Kiran
          Hello,
          I dont think so. I used only UsB cable, and never Saw there aby Ethernet plug
          Iam really desprated
          • Kiran Otter
            • Dec 2013
            • 1109
            Any accessory cards like a network card, would be located in the back of the printer behind the door on the right (as you face the back of the printer.)
            500NIC — ImgBB
            If you just see two blank metal plates there, then there is no network card. In that event, I would guess you have a bad electronics module.
            Kiran
