HP m601 not fusing
  • Tom
    • 344
    HP m601 not fusing
    Hello, I have a M601 printer that intermittently doesn't want to fuse properly and it's smearing the toner on the pages. I know it has to be something with the cam not moving properly so that it has pressure but I don't see anything wrong with the fuser. I replaced the fuser with another and it does the same thing. Unplugging and replugging makes it go away for awhile. It has latest firmware. Anyone seen this?
    • 22999
    I have to start with the easy things first. Have you seen examples of this not-fusing? Is it on heavy or glossy media. The enduser does need to specify the media type for it to fuse properly.
