HP cm4540 no black
  • stobby2
    • Oct 2013
    • 137
    HP cm4540 no black
    Hi Guys
    Got an HP CM4540 will not print black. Not drum unit. All colours print fine so suspect no voltage charge to black drum as if machine stopped part way through no toner on black drum but there is on the colours. Any help appreciated
  • Drivee
    • Nov 2020
    • 322
    Re: HP cm4540 no black
    Are you 100% sure that cartridge is not defected? Maybe just a seal is not pulled, do you see toner on DEV roller?
    • ZoZo
      • Jan 2020
      • 30
      I recently ran into an issue where the laser shutter in the cartridge cavity was broken & covering the laser. Might be worth a look.
      • stobby2
        • Oct 2013
        • 137
        Thanks for that. Customer states that they tried a new toner which l believed (but who knows!!!). I think l will get a replacement in before l start looking further. I will also check the toner on dev roller as well
        Thanks again
        • stobby2
          • Oct 2013
          • 137
          Interesting possibility. Will check this out and thanks for the advice. Much appreciated
          • stobby2
            • Oct 2013
            • 137
            Hi Guys
            Tried new toner, still no black print. Shutter is open on black laser unit. No toner on dev roller. Any further ideas would be appreciated. I will start to have a go after Xmas hopefully can locate a fault somewhere
            • ZoZo
              • Jan 2020
              • 30
              There's a contact on the upper cartridge guide, is that bent or out of place?
                Originally posted by stobby2
                Hi Guys
                Did they pull the seal tab between toner/dev?
                • JLSam
                  • Jun 2015
                  • 605
                  Dude, I just had this conversation with a client not 5 mins ago.
                  :Head Banging:
                    :Head Banging:
                    IMAGINE how many times i did in 31 years in the industry!?
                    [emoji16]
