This code is not in the service manual, so it has no solution either. The screen says something to do with the print head?
The only thing I can find is a list of codes that have gibberish next to it, which says will help determine the resolution. Huh?
I am the technician that is supposed to fix this thing.
Here's part of the list I found for this error
62.0F.YZ, 62.0X.YZ, 62.11.YZ, 62.12.YZ
The print engine has encountered an error. Print head and Ink Delivery Errors.
Any help would be greatly appreciated. HP support basically listed the same thing with no resolution. Thank you
- 62.0X.YZ Printbar failed
62.0x.02 | Indicates die number; between 0-9. | PEN_NO_PEN_IO |
