Error 94:11 on a Designjet Z6800
  • J. Smith
    • Apr 2025
    • 8
    Would anybody have any idea how can this 94:11 error ( Designjet Z6800 ) could be tackled? The machine had, initially , a different problem - 24:10 error ( which I'd managed to get rid of after an EEROM reset). Next step after the reset was to replace the encoder strip ( had discolored portions). Also replaced a couple of bad printheads. Machine had performed the PH alignment- looking good, and then the first print job sent came out fuzzy and with doubled letters. Any attempt to print an internal page had triggered the 94:11 error. Upgraded FW- just in case. Replaced the ESP for another one harvested from a Z6100, ran ESP tests ( OK) but still got the 94 error. I am at the end of the rope... Help?
  • Kiran Otter
    • Dec 2013
    • 1109
    Sounds like you tried everything I'd suggest. What media/paper are you selecting when you load it?
    Kiran
    • J. Smith
      • Apr 2025
      • 8
      It's HP coated paper. Same one used all the time ( this client doesn't use specialty paper)
      • Kiran Otter
        • Dec 2013
        • 1109
        OK, so I'm told by HP this is a print quality issue. Run the print quality report and clean/replace any printheads that are not working. If they all seem to be working, post a pic of the print for me.
        I know this doesn't sound like it makes sense but my contact has seen this issue many times.
        Kiran
        • J. Smith
          • Apr 2025
          • 8
          Hello Kiran,
          Please find the print quality test page attached. Printhead#8 is obviously failing and some time next week ( probably Tuesday), it will be replaced and I'll let you know if any change has happened. Thank you so much for your input !
          • J. Smith
            • Apr 2025
            • 8
            Hello Kiran,
            I've just poked the client since he didn't bother to keep me updated and he's confirmed he had printed 8 posters without any issue ( no 94 errors) after replacing (as you'd suggested ), printhead #8 !!! First time for me when I ran into this issue and I agree, I was a bit skeptic... But it works and this is what matters ! Thank you again for your priceless help !
            • Kiran Otter
              • Dec 2013
              • 1109
              You're welcome, and thank you for posting the outcome.
