Laserjet M602
  • scanmc
    • Mar 2015
    • 182
    Laserjet M602
    I've got a laserjet M602 out in the field that continually says tray#2 lifting, but never comes to ready. I've changed out the toner cartridge & fuser. There is no paper stuck anywhere in the machine.. I've even swapped out the power supply and the DC controller with no luck. Any input would be appreciated.
  • Murv
    Sr. Escalations Analyst
    • Mar 2021
    • 182
    Have you checked the lifter drive for a crack? Common issue on that series.
    • Lance15
      • Jun 2015
      • 1086
      Lifter drive assembly - RM1-4585-000CN
      • scanmc
        • Mar 2015
        • 182
        Don't think it's the lift motor. The machine has a tray 3 attached, and when you remove tray#2, it changes the message to tray#3, lifting with the same results
