HP laser jet P2015 has error lights on the are not listed in the service manual.
  • tonerjockey
    • Apr 2014
    • 567
    Hello, there are 6 "idiot lights" on the top cover. the upper 3, the jam, the toner and paper are all 3 on solid.
    this configuration isn't listed in the HP service manual.
    I checked that it had paper, had a toner cartridge and there was no paper jammed inside.
    has anyone run into this issue??
    thank you
  • Lance15
    • Jun 2015
    • 1089
    The formatters on these printers suffered from cracked solder joints under the main BGA chip.
    I baked (reflowed) several of these formatters to fix.
    • tonerjockey
      • Apr 2014
      • 567
      oh really. i had tried way back to bake the HP P3005 or P3015 i forget now. i didn't have any luck, but i told someone about it and it worked for them. plus several on Smarka.
      thank you for the info reminder.
