LJ Enterprise M605 unsupported bundle
  • snellcat1960
    • Mar 2015
    • 4
    Hey guys,
    We inherited service on a LaserJet Enterprise M605 being used as a check printer using MICR toner. When we checked out the machine we found it wouldn't boot past 1/8. I ordered a formatter board, installed it and attempted to update the firmware using the docs on the HP support site. I downloaded the latest version of firmware (the only one that was available to download) and every time I try to load it into the machine I get a message saying "unsupported bundle." It sure seems like I'm doing everything correctly but I'm not sure why it's failing. Any thoughts?
  • johnyb
    • Feb 2011
    • 167
    Re: LJ Enterprise M605 unsupported bundle
    Hi
    Sometimes you need to format the disk, then clear the password, then install firmware once completed transfer select continue to boot!
    you might want to try another version.
    ftp://ftp.hp.com/pub/softlib/softwar...JM604_605_606/
      • 23008
      I suspect that there is special firmware for the MICR printer, but don't know for sure. =^..^=
      • snellcat1960
        • Mar 2015
        • 4
        I've tried every version of firmware available on the FTP site and still get the "unsupported bundle" message. I'm wondering if I should order a new eMMC.
        • Wild Bill
          • Jul 2005
          • 774
          Yes that's it
          Izzy
          • tech28
            • Jun 2013
            • 434
            Have 605's using micro toner for checks. Didnt need any new firmware or anything. Just delivered, hooked up and go to go.
