HP pagewide 477dn error 8B380001
  • gideon
    • 283
    On start up I get the pagewide screen and then it turn to all blue screen with the number 8B380001.
    This error is not in my manual, any idea?
  • GIUBOSS
    • 1436
    Re: HP pagewide 477dn error 8B380001
    Did the error pop up after transporting the printer?
    Reset the printer
    Turn the printer on, if it is not already on.
    Wait until the printer is idle and silent before you continue.
    With the printer turned on, disconnect the power cord from the rear of the printer.
    Unplug the power cord from the wall outlet.
    Wait at least 60 seconds.
    Plug the power cord back into the wall outlet.
    Reconnect the power cord to the rear of the printer.
    Turn on the printer, if it does not automatically turn on.
    Wait until the printer is idle and silent before you proceed.
    Also, Update the printer firmware
    • Crowfeather
      Printer firmware is !&$!
      • Mar 2021
      • 130
      All blue screen faults on the pagewide series relate to firmware issues. If you contact HP they will ask you to reset, then tell you to buy a new machine. (They don't like people fixing their stuff).
      On the Pagewide's there's a preboot menu you can try and access and then do a firmware restore.
      Disconnect Power
      Hold power button in while reconnecting power
      HP logo appears then dissapears - continue holding for 5 seconds
      Release the power button
      Touch Home Button
      Back button
      home button twice
      After new screen appears touch home button
      Press power button to enter MFG mode.
