49.38.0d
  • CopyTech03
    • Jul 2020
    • 54
    [Error Code] 49.38.0d
    HP m605 with an error 49.38.0d. The printer will come to Ready, once it prints out a print job or internal print (Configuration Page) it will give this code. Starting happening after a power surge. Tried updating the firmware and doing a Cold Reset. Does anyone have any other ideas?
  • DRichard
    • May 2008
    • 482
    Re: 49.38.0d
    From the manual... "A firmware error occurred. Corrupted print jobs, software application issues, non-product specific print drivers, poor quality USB or network cables, bad network connections or incorrect configurations, invalid firmware operations, or unsupported accessories can cause this error." In short, it appears to be a catch-all code for when the printer has lost its shit.
    "Enjoy every sandwich."
    -- Warren Zevon
    • DRichard
      • May 2008
      • 482
      Re: 49.38.0d
      Recommended action for call-center agents and onsite technicians (NOTE:LaserJet formatter PCAs are rarely the root cause of 49 service errors. Please do not replace the formatter unless troubleshooting has identified the formatter as the root cause.)1.
      Turn the printer off, and then on.
      2.
      If the error persists, check the following:
      The error might be caused by a network connectivity problem, such as a bad interface cable, a bad USB port, or an invalid network configuration setting.
      The error might be caused by the print job, due to an invalid print driver, a problem with the software application, or a problem with the file being printed.
      Upgrading the printer firmware might help resolve the error.
      -- Warren Zevon
        • 23007
        Re: 49.38.0d
        I'd start by taking it off the network, booting up, then testing while off the network. If the error does not re-occur off the network, you may have a corrupt print job, wrong print driver, or non-print data hitting the printers IP address. =^..^=
        • CopyTech03
          • Jul 2020
          • 54
          Re: 49.38.0d
          Have it off the network, but still getting same code when printing out internal prints
            • 23007
            Re: 49.38.0d
            That's not good.
            Try firmware, if it will take. =^..^=
