HP LaserJet 8150N
  • CWalls
    • Jun 2025
    HP LaserJet 8150N
    Hi there, need help with a HP LaserJet 8150N printer, the problem started with the replacement of the Fuser the tech guy changed it but if I print a 30 page document after the page 15 or so the toner comes of the paper there is no error message, I have called 2 diferent tech companys and 6 fusers have ben replaced and still the same problem (this only hapens if I print on Legal paper).
    Any Idea?
    Thank's in advanced
  • TheOwl
    • Nov 2008
    • 1732
    I am presumming that you have your 'Legal' paper in one certain cassette. Make sure that the paper type for that cassette is set to the type of stock that is being used.
    • TheOwl
      • Nov 2008
      • 1732
      Sorry, one other thing I just thought in case the paper type is correct.
      I have seen this in a couple of the smaller HP printers, not the 8150, but works one the same principle.
      I have had bad power supplies cause the same issue. They weren't supplying enough voltage to the fuser. It would heat slower than other machines, but heat up all the same. As soon as it came to longer print runs, the power supply didn't have enough voltage to keep the fuser at the right temp during the run.
      Just another thought to add to my previous post.
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        Good call Owl, the 8150 has power supply issues. 9 times out of 10 if you get a fuser code on this machine, it really needs a power supply. I would check the media type first.
        • JustManuals
          • Jan 2006
          • 9838
          Actually its cold solder joints on the power supply that gives the problem and can usually be fixed by re-soldering them.
          HtH
          Paul@justmanuals.com
          • CWalls
            Thank's for the info I'll start working on it and let you know if it worked
            • c.davis419
              • Dec 2008
              • 7
              I know it sounds silly, but you should check the fuser assembly itself and verify that the nip levers are released. This fuser has two levers that when pushed into the up position unload the spring tension between the fuser rollers to prevent flat spots from occuring while in storage. If they are left up, the printer will exibit the exact symptoms you've described.
                • 22997
                Yeah, I've got a customer who has to fiddle with the "envelope" pressure levers. I can usually get this one handled over the phone now. =^..^=
