HP Firmware
  • soaponarope
    Pat McGatt
    • Nov 2020
    • 30
    [Misc] HP Firmware
    Do HP printers (particularly E55040) update firmware automatically nowadays and if so can you turn it off and if so how?!
  • wav
    • Oct 2021
    • 285
    Re: HP Firmware
    hi these machines will only update once you have requested it to via usb.
      • 23009
      Re: HP Firmware
      The wide format devices do have a built in utility that can update firmware by itself, but it can lead to interesting issues. If you have slow or unreliable internet service, a firmware update can begin ... but never finishes. It locks up the device. Powering OFF/ON will restore the device until the next time it tries to do that firmware update, then it happens again. On most of my wide format devices it is left on. On a few devices I have disabled the automatic firmware function, due to repeated disruptions. I also disable the message: "A firmware upgrade is available ..." because then some adventurous soul starts it, then it gets stuck. There is never an issue with USB upgrades. =^..^=
      • wav
        • Oct 2021
        • 285
        Re: HP Firmware
        Hi these models are a managed version of a Hp m552,m553
        they have a small 16 or 8gb emmc card or even a 320gb Seagate secure hdd installed.
        I haven't seen these machines ever ask for a update as in the service menu you can do a future smart update via usb and via the embedded site.
        I know on the certain pagewide models you can go into the enable disable menu and enable firmware update from there.
