HP M453-M454 series Firmware
  • M1963
    • Jun 2017
    • 67
    greeting,
    maybe someone has an older firmware for HP Pro M454 series (does not recognize black toner) to use compatible toners ?
    thank you
  • M1963
    • Jun 2017
    • 67
    Re: HP M453-M454 series Firmware
    current version
    SHMNTOXXXN002.2230D.00 2022-07-22
    maybe some version from 2019.
    which allows the use of replacement toners
    • ZoZo
      • Jan 2020
      • 30
      ftp.hp.com
      • M1963
        • Jun 2017
        • 67
        thanks, but it doesn't work
        • wav
          • Oct 2021
          • 285
          hi pm me i have an archive of lots of firmware.
          • M1963
            • Jun 2017
            • 67
            Has anyone managed to restore an older version of the firmware?
            • wav
              • Oct 2021
              • 285
              Hi if you connect the machine and go to network and enable ftp and then send the firmware via command prompt
              It should load or goto service menu and see if fw downgrade is an option.
              • M1963
                • Jun 2017
                • 67
                HP M455 is only a printer, not MF, no ftp, at least I haven't found it.
                . when I start the firmware exe.file does not allow to select the offered printer and it still does not work.
                your help means a lot to me
                • wav
                  • Oct 2021
                  • 285
                  Hi sorry i meant Goto the embedded web server from the ip address of the machine then go to network and see if ftp it's an option to be ticked and then apply it.
                  • M1963
                    • Jun 2017
                    • 67
                    Hi, I tried to connect via ftp, unfortunately it doesn't work. The printer does not support the ftp service.
                    do you have any other ideas.
                    Thank you for your support
                    • wav
                      • Oct 2021
                      • 285
                      ill send you a file and for you to use usb. to force send the firmware
                      later tonight as i dont have the file here
                      • JHahn7837
                        • 11
                        Hi, do you have the older firmware that you can share? We have a 454 that is locked out from using non-oem toner.
                        • printelcom
                          • Nov 2022
                          • 4
                          Hi, do you have the older firmware that you can share? We have a 454 and m479 that is locked out from using non-oem toner.
                          Thanks!!
                          • ckm_one
                            • Jul 2023
                            • 1
                            Hi, someone can send me firmware for the printer HP m454!? Thankx
                            • GIUBOSS
                              • 1436
                              try here....
                              HP Printer Firmware Downgrade Download | Old Version Available
