T930 has: Blank Screen, Blue LED "on" above rear switch, Formatter I LED "Flashing"
  • pbrooks259
    • Jun 2017
    • 162
    CORRECTION!!!! this is a Z6200 (NOT T930): Blank Screen (front panel status: off), Blue LED "on" above rear power switch, Formatter I LED "Flashing"
    1st off, Kiran has suggested I first try replacing the main pca battery. (At that time I had only relayed these symptoms: 8 beeps, flashing front power button with white screen, and solid blue LED on the back power button.)
    This has all the signs of a BAD Hard Drive per the service manual. I suppose it could be a bad cable connection. I am fairly certain it is a bad Hard Drive.
    It is a few hundred miles away; it is NOT in front of me. I am wondering what other parts I should bring along "just in case" it is NOT a bad hard drive.
    I am thinking I should maybe bring along a replacement front panel and formatter (kinda pricey; don't really want to but maybe I should), just in case.
    Thanks for any input.
  • Kiran Otter
    • Dec 2013
    • 1107
    Re: T930 has: Blank Screen, Blue LED "on" above rear switch, Formatter I LED "Flashin
    I agree, probably the HD. Could be PSU.
    The CMOS battery on the main PCA (motherboard) can also cause weird initialization issues.
    Kiran
