HP designjet T830 error code 1800-0000-0000
  • Devita Printing
    • Mar 2023
    • 4
    [Error Code] HP designjet T830 error code 1800-0000-0000
    Need help... my HP DesignJet T830 got error code 1800-0000-0000 everytime i print. it only prints like a few centimeters then stop. when copying, same case happens. after document scanned, it only prints a few seconds then stop. scanner function is OK. no such error code in the service manual. any idea? thanks.
  • Kiran Otter
    • Dec 2013
    • 1118
    Re: HP designjet T830 error code 1800-0000-0000
    I'm not sure you have the error correct. Could you take a picture of it and post it? There are no errors in that format.
    Kiran
    • Kiran Otter
      • Dec 2013
      • 1118
      I did some checking and apparently this error does occur sometimes, and it sounds like it's related to the printhead or carriage. You might try reseating it, or ultimately replacing it. Or if you have replaced it, and still get this issue, it may take a carriage and main PCA to resolve it.
      You might try an OOBE reset. Power off the printer. Hold the power button for 30 seconds, then press home, back, home, home.
      Kiran
      • Kiran Otter
        • Dec 2013
        • 1118
        It was brought to my attention a similar error does appear in the service manual for the T200/600. See attached. Sounds like a new main PCA is in order. But I would rule out the printhead/consumables first.
        Kiran
        • Devita Printing
          • Mar 2023
          • 4
          Kiran
          will back soon with picture. thanks.
          • Devita Printing
            • Mar 2023
            • 4
            this is the error shown in lcd panel
            • Devita Printing
              • Mar 2023
              • 4
              Kiran
              printhead replaced. doesn't solve the issue.
              • Kiran Otter
                • Dec 2013
                • 1118
                Then it sounds like you need a new main PCA, and/or carriage assembly. Remember you can only replace one electrical part at a time. Unfortunately I don't have a way to determine if it's one or the other. My guess would be the main PCA.
                Kiran
