HP LaserJet Pro 200 M276nw print problem
  • max299x
    • Dec 2022
    • 6
    Hi,
    I have an HP laserjet pro m276nw. When I try to print it seems to crash. I have tried changing the pickup roller thinking it was worn out but the result has not changed.
    Occasionally it manages to print a sheet but I have noticed that it only prints black with a few hints of colour. I attach a video to better understand the problem
    Thank you all for your help.
    IMG_0910.mov - VEED
  • Lance15
    • Jun 2015
    • 1088
    Re: HP LaserJet Pro 200 M276nw print problem
    Did you use a genuine roller (RM1-8047) or aftermarket roller?
    If you look from the rear of the printer, do you see the pickup roller rotating?
    • max299x
      • Dec 2022
      • 6
      No the pickup roller is aftermarket. I changed both the pickup and the separator.
      From behind I can't see anything because it's closed. Removing the paper tray I can see the pickup roller just fine.
      Could it be a toner problem this strange noise it makes when I try to print?
      Then I noticed that those few times it does print, the paper comes out very slowly.
