print the document in black and white even if one of the color cartridges is empty
  • nicovon
    • Nov 2022
    • 54
    Good morning,
    as we all know hp printers, when at least one of the cartridges is empty, it is not possible to print.
    Is this policy legal?
    I personally have run out of yellow but would like to print a document in black and white.
    I don't want to buy the yellow cartridge because honestly I never use it.
    the question is: is there a way, only if legal, to print the document in black and white even if one of the color cartridges is empty?
    Re: print the document in black and white even if one of the color cartridges is empt
    Originally posted by nicovon
    Good morning,
    does the doc have one pixel in color or composite color for grey scale?
    are you using OEM toners?
    • nicovon
      • Nov 2022
      • 54
      Thanks for the reply. This is a PDF document with no images, just text. The font color is black. The cartridges are the original ones included with the printer. The printer model is: hp color laser mfp 179fnw
      • mojorolla
        The Wolf
        • 2627
        Good morning,
        Open the PDF file in WORD, highlight the text then right click the text and selects Fonts. Under font color, choose more colors at the bottom. Click the custom tab and it will display the breakdown of the colors. If the values are all zeros like in the example below, the text is pure black.
        • nicovon
          • Nov 2022
          • 54
          [ATTACH=CONFIG]58682[/ATTACH] [ATTACH=CONFIG]58683[/ATTACH]
          A thousand thanks! Are you telling me that if I convert the documents I need to print to pure black, I'll be able to print even if I'm out of color toner?
            • 37521
            Good morning,
            If you never use yellow, why is it empty?
            Depending on the type of printer all cartridges are used for automatic adjustment.
            • For Inkjet printers it will fail automatic nozzle testing
            • For lased it won't be able to execute auto image density control
              • 30279
              Yes it's legal and Nope by a yellow
              • nicovon
                • Nov 2022
                • 54
                Is auto image density control necessary? If the printer does not do it due to lack of toner, could there be a malfunction?
                  • 37521
                  It is dome a minimum of once each day of operation. It is controlled by the firmware. Custom firmware to eliminate it will most likely cost you a few thousand dollars up front and could take a few weeks to write. A yellow cartridge is considerably less.
                  • nicovon
                    • Nov 2022
                    • 54
                    please could you give me an example of composite color for gray scale?
                    • nicovon
                      • Nov 2022
                      • 54
                      if I decide to modify the firmware (I will never do it) what will be the damage I will encounter?
