Designjet T1100 87:11 Fail nScan Axis Length: 1070368. Too SHORT
  • theengel
    • Nov 2011
    • 1784
    I had a customer who got 87 jams every time they loaded paper. If they loaded the paper and then turned on the printer, there would be some sort of 'paper loaded incorrectly' error.
    I replaced the carriage unit (which includes the encoder sensor), the encoder strip, and the belt.
    Still getting the same thing. When I do a Scan Axis test, I get through everything until after the left side bump. Then it says
    ERROR: 87:11
    FAIL Scan Axis length:
    1070368. Too SHORT.
    Check path is free.
    Need mechanical repair.
    Press any key to continue.
    I can't think of what would cause this. The starwheel, formatter, and electronics module all test good.
  • Kiran Otter
    • Dec 2013
    • 1108
    Re: Designjet T1100 87:11 Fail nScan Axis Length: 1070368. Too SHORT
    Only thing I can think of is it might be the cutter. Try removing the cutter and testing it again.
    I also had a case where a customer bough their own parts and it took me a while to realize they got the wrong encoder strip. It was just a hair too short and very difficult to install. The encoder strip should have a part number on it so you can verify.
    Kiran
    • theengel
      • Nov 2011
      • 1784
      The original encoder strip looked perfect. I only replaced it to eliminate it... I stole it off a Z2100 from the shop.
      You're thinking the carriage is running into the cutter causing it not to be able to travel all the way left?
      That might be something. On the left bump test in the scan axis test, it goes all the way to the left, and then it begins a "checking scan axis length" But the carriage stops just before it gets half way through and gives me the "too short" error. As if it was stopped by a paper jam. But I feel no resistance in the carriage sliding all the way back and forth... and it's already gone from one side to the other side. It makes no sense.
      • theengel
        • Nov 2011
        • 1784
        I wonder if there's a weak spot in the cables. I saw the Z2100 and T1100 have the same trailing cables... maybe I'll bring that with me to see if it's poor communication between the encoder sensor and the eModule.
        • Kiran Otter
          • Dec 2013
          • 1108
          Umm.. the encoder strip for the T1100 is a different part number from the one for the Z2100. HP wouldn't give them different part numbers if they were the same part. You might want to put the old one back in and see what happens.
          Kiran
          • theengel
            • Nov 2011
            • 1784
            I'll probably do that, but the old one has all the same problems as the Z2100 one. I hate to put money into it that won't produce a solution. But maybe I haven't eliminated it until it gets a new one.
            • wcanonw
              • Aug 2014
              • 404
              Originally posted by theengel
              the original encoder strip looked perfect. I only replaced it to eliminate it... I stole it off a z2100 from the shop.
              That might be something. On the left bump test in the scan axis test, it goes all the way to the left, and then it begins a "checking scan axis length" but the carriage stops just before it gets half way through and gives me the "too short" error. As if it was stopped by a paper jam. But i feel no resistance in the carriage sliding all the way back and forth... And it's already gone from one side to the other side. It makes no sense.
              the part you removed from the z2100 is not compatible with t1100, check the service manual and compare their part codes
              • wcanonw
                • Aug 2014
                • 404
                HELLO GOOD MORNING, HAVE YOU DONE EVERYTHING INDICATED IN THE SERVICE MANUAL ABOUT ERROR 87?
                System Error: 87:YZ
                Problem Description:
                Problem finding the Scan-axis encoder reading.
                Corrective Action:
                Try the following:
                1Upgrade the firmware.
                2Clean the Encoder Strip.
                3Replace the Encoder Strip. See Encoder Strip, spring and nut (T1100/T1100ps/T610) on page 6-96 or Encoder Strip, spring and nut (T1120/T1120ps/T620) on page 6-99.
                4Replace the Carriage PCA. See Carriage PCA (T1100/T1100ps/T610) on page 6-177 or Carriage PCA (T1120/T1120ps/T620) on page 6-182.
                5Replace the Trailing Cables. See Trailing Cable (T1100/T1100ps/T610) on page 6-102 or Trailing Cable (T1120/T1120ps/T620) on page 6-109
                • wcanonw
                  • Aug 2014
                  • 404
                  FROM THE HP DESIGNJET T1100 SERVICE MANUAL
                  Q6683-60242 24 inch
                  Encoder Strip (including Encoder Strip Spring and Nut) T1100/T1100ps/T610
                  Q6687-60094 44 inch
                  FROM THE HP DESIGNJET Z2100 SERVICE MANUAL
                  Q6675-60071 24 inch
                  Encoder Strip (including Encoder Strip Spring and Nut) Z2100/Z3100/Z3100ps/Z3200/Z3200ps
                  Q6677-60024 44 inch
                  • theengel
                    • Nov 2011
                    • 1784
                    The different part numbers do not necessarily indicate different parts. Like I said, I only did it to eliminate it as a problem. The original one looks perfect. When I line the two up, they look identical... although, the space between the lines can't really be measured. Anyway, if the problem had changed after putting on the new strip I would be suspicious of it. But both strips produce the exact same problem, and in the same places. I think there's something else going on.
                    • Kiran Otter
                      • Dec 2013
                      • 1108
                      The pitch of the lines in the encoder strip could have everything to do with the difference between them. And it's very easy to miss damage to the markings. But assuming you have a good and correct encoder strip, I'd then consider the trailing cable as a possibility.
                      Personally I'd get a new encoder strip first.
                      Kiran
                      • wcanonw
                        • Aug 2014
                        • 404
                        reviewing the z2100 part code on the internet. there are some that sell it as compatible for T1100, strange that I have not yet done the test to see if it is really compatible. Check these links and say your opinion..
                        Q6677-60024 Encoder strip for HP T610 T620 T770 T1100 Z2100 Z3100 ps Z5200 44" 192816000739 | eBay
                        • wcanonw
                          • Aug 2014
                          • 404
                          If someone gives his opinion that if the encoder of z2100 and t1100 are compatible, you just need to change the trailing cable and finally update the firmware :confundido:
                          • Kiran Otter
                            • Dec 2013
                            • 1108
                            I wouldn't trust any of those sources as knowing what's compatible. In all my years dealing with HP, they have never put out the same part with two different part numbers. If the part numbers are different, the part is different. And even if there's some rare case they did somehow have 1 part with 2 part numbers, I would still presume they're different somehow. Use the right part and number for the machine you're working on.
                            Kiran
                            • wcanonw
                              • Aug 2014
                              • 404
                              hi kiran, about canon and hp plotter. Is there a way to create a color profile to improve the color quality? I have some clients who put compatible ink on their plotter and the colors come out very yellow or saturated.
