Looking for a brand new printer with particular specs
  • Artefil
    • Aug 2023
    • 16
    [Misc] Looking for a brand new printer with particular specs
    Hello,
    A customer of mine is looking for a brand new printer (color one will be prefered) with a DB25 connector :
    1-For security reason can't use an USB connector,
    2-Program which is using the printer is written under DOS 6.22
    Any idea?
    Artefil
    • 22997
    Re: Looking for a brand new printer with particular specs
    That's going to be a problem for you. Parallel cable printing had gone obsolete a long time ago (20 yrs ago?).
    Your only option will be an ancient refurbished HP Laserjet, as far as I know. =^..^=
      • 8142
      ... I recommend the customer buys a box of colour crayons.
      DOS 6.22 is pre Windows 95, before Windows 7.
        • 37316
        If by DB25 you mean RS-232 Serial interface port on the printer, about all you are going to find are serial receipt printers and they are more likely to only have a DB9 connector. If instead you mean to connect to a DB25 parallel port on the computer Ricoh and most like a other MFP manufacturers have an IEEE 1284 interface option.
        Otherwise, it is time for our customer to move out of the dark ages.
        • mloudy
          • Oct 2015
          • 777
          You can still get a new mono Lexmark printer with an optional RS-232C Serial Interface Card or a parallel 1284-B Interface Card. The color printers do not have these options.
          • rthonpm
            • Aug 2007
            • 2848
            Originally posted by Artefil
            Hello,
            Any idea?
            Artefil
            A time machine to take them back to 1998.
            Sent from my Pixel 6 Pro using Tapatalk
