HP Laserjet M281 paper jam in path. open tray 2 and rear door error.
  • ginolab19
    • Sep 2023
    • 5
    hi guys im newly here. can someone help me. I have printer laserjet m281 getting paper jam in path. when im trying to print 1 pages it was stuck between fuser and roller. i check there is no piece of paper stuck and also i change the fuser assembly but still no luck. when i checking the fuser is not rotating to take paper inside the fuser. is there someone help to resolve this issue. thanks guys
  • Mitch Barron
    • Mar 2013
    • 180
    Re: HP Laserjet M281 paper jam in path. open tray 2 and rear door error.
    Have you tested the motor in service mode? how about your pick up drive motor and clutch
    • ginolab19
      • Sep 2023
      • 5
      not yet bro. i will try and i update you if it will work. thanks
      • ginolab19
        • Sep 2023
        • 5
        hi bro. in my printer there is no service mode to test the motor.
        • ginolab19
          • Sep 2023
          • 5
          is there anyone can help me. please
