HP 4250/Envelope Feeder
  • cucuklotz
    • Mar 2007
    • 611
    HI,
    I have to install 75 sheet envelope feeder to 4250,the feeder is new but came W/O instructions. Is there anything I need to know about installing feeder or is it relatvely easy to put on machine?
    THANKS ANDY
  • prntrfxr
    • 1622
    It should be exactly similar to the HP 4000 series machines. Just open the MP door, line it up (connector on the right), and insert into machine. Make sure you do it with the power shut off. When it's installed, power up the machine and it should be automatically recognized.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • cucuklotz
      • Mar 2007
      • 611
      HP 4250 / Envelope Feeder
      HI,
      AS ALWAYS, Thanks for the response. Ill be setting it up Tues or Wed. Ill let you know.You have saved me again and again. THANKS ANDY
      • leroyal
        Expert on The Obsolete
        • Sep 2007
        • 156
        If it's going to networked, you might need RIGHTS to enable it.
        This happened to me with a Large Capacity Cassette I installed.
        I know what I know better than anyone else knows what I know.
        • cucuklotz
          • Mar 2007
          • 611
          HI,
          Thanks for reply,For now it wont be networked.
          Andy
